TCL : add information
hello ,
I want to add information in my clsfile on each load/tool :
I have two files
First file : info.txt
Second file : 1001.cls
Problem
my line is added and not replaced
and my second problem in my output file, the lines are not replaced according to the tool number
thanks for the support
info.txt :
OUTIL                     IE           IF
LOAD/TOOL,1,ADJUST,1      2050         1500
LOAD/TOOL,2,ADJUST,2      3500         1200
LOAD/TOOL,14,ADJUST,14    8850         1600
1001.cls :
TOOL PATH/TC-FR-DIA32-R0.8,TOOL,TC-FR-DIA32-R0.8
TOOL PATH/TC-FR-DIA40-R0.8,TOOL,TC-FR-DIA40-R0.8
TOOL PATH/TC-FR-DIA20-R0.8,TOOL,TC-FR-DIA20-R0.8
Finally I would like my cls file looks like this:
LOAD/TOOL,1,ADJUST,1,2050,1500
LOAD/TOOL,2,ADJUST,2,3500,1200
LOAD/TOOL,14,ADJUST,14,8850,1600
my code :
set fin [open "info.txt" r]
set fout [open "1001.cls" r+]
while {![eof $fout]} {
set data [gets $fin]
set match [ string match {*LOAD/TOOL*} $data]
set ligne [gets $fout]
set record [ string match {*LOAD/TOOL,*} $line]
if {$match == 1} {
set info [join $data ,]
if {$record == 1 } {
set lg [llength $line]
set ligne [string replace $line $lg end $info]
puts  $fout $ligne
close $fout
close $fin
Production: NX11.0.2.7,VERICUT 8.1.2
Development: Tcl/Tk, Gnuplot
www.adgroupe.com
Re: TCL : add information
You have a } too many to start with.
You read one line at a time in both files. Why not read in the info file first into a list and try to match these with the cls?
You have not put anything into $line before you use it.
Search around on the tcl wiki  for help on tcl with examples.
W10 NX12.0.2.9
testing v1847
I have not checked my code before posting, actually too many}.
yes, I have realized a different code since Monday, first I read all my info.txt and not line by line, then I realized a temporary file 1001.cls.
Finally, my code looks like this:
not optimized, but it works
set fout [open "1001.cls" r]
set out [open "1001.tmp" w]
set record [ string match {*LOAD/TOOL*} $line]
# my code
set fin [open "info.txt r]
set fd [read $fin]
close $fin
 foreach line $fd {
# my code
 close $fout
 close $out
file rename -force "1001.tmp" "1001.cls"
www.adgroupe.com
