(TNC 620) How to create CYCLE 203 parameter in Post Builder (NX 12)
Does anyone know how to create the below parameter for CYCLE 203 in Post Builder?
Below is the current parameters that available in the post:
Thank you.
Re: (TNC 620) How to create CYCLE 203 parameter in Post Builder (NX 12)
how to add new parameter: RMB - new.
But important question will be: what variable to use because there is no every variables for everything.
You can make them hardcoded or calculated from existing by some logic.
If you want to control them check this thread:
https://community.plm.automation.siemens.com/t5/Discussion-Forum-NX-Manufacturing/How-To-Create-Cycl...
