TNC Tapping simulation
I have a question about TNC post (5axis BC-TT)
When i try machine simulate about tapping cycle (cycl def 207), there is no motion in the ISV.
see this video.
(view in My Videos)
How can i get set the tapping motion?
7 REPLIES 7
Re: TNC Tapping simulation
Do you have a sub-program that contains the motion of cycle 207?
Is this sub-program activated for cycle 207 in the MCF file?
Production: NX12.0.2, VERICUT 8.2, FBM, MRL 3.1.7 | TcUA 10.1 MP7 Patch 0 (10.1.7.0) | TcVis 11.4
Development: C (ITK), .NET, Tcl/Tk Testing: NX (1876) | AWC 3.4 Preparing: -
I don`t have 207.h Tapping sub prg.
And not activate in MCF file.
Then you need to create one or use the subprog folder and MCF file of a more recent NX release if it is included there.
Without the sub-programs of the cycles, there is no cycle movement.
Siemens NX includes only Subprogram for Cycle 200 and 203. If you need other Cycles you have to buy it from the Machine Vendor or from the Heidenhain direct.
Thank you for your advice. i`ll check that in Heidenhain direct.
Please contact me, if you know who has '207.h' file.
I was able to get the files I needed from GTAC. I suggest contacting them. Heidenhain was reluctant to give me the files, and they didn't work anyways.
...that is not good.
How can i get them? about heidenhain cycle code.
Should i have contact to GTAC?
