TOOL ABC not Available in Simulation Control Panel
I don't see a Display Coordinates drop down menu in Simulation Control Panel to select "Tool ABC Coordinates" or "Machine Coordinates"?
Only "Tool IJK Coordinates" is displayed.
Is there a setting I need to change?
Thank you for your time.
Re: TOOL ABC not Available in Simulation Control Panel
This option is moved to this area:
Marek Pawlus, NCmatic
Production: NX 12.0.1
Development: C#, Tcl/Tk, CSE
Thank you for your reply.
