Tecnomatix Machine Configurator
Hi everybody,
I would like to customize the CSE drivers to implement the simulation of mill-turn multi-channel machine that is situated in the campus. From the different videos I understood that I need a Tecnomatix Machine Configurator.
Where to find it and how to download it on my PC?
P.S. Have a student license from my university.
Thank you for your help.
Re: Tecnomatix Machine Configurator
Hello Natalie,
You can find the Installer for Machine Configurator in the download section of GTAC
https://download.industrysoftware.automation.siemens.com/
In the picture below you can see were it is located
To get into the GTAC you must have an Login via Webkey. You can find your Webkey in your Log file.
Simple search for "Webkey"
greetings,
Andre
