Re: Telescopic machine protection simulaion (ISV)
Siemens Pioneer Siemens Pioneer
Siemens Pioneer
Stefan, thanks for your feedback.
I really would this kind of simulation to be more realistic with machine.
But I understood and I did the most simple and efficient way.
A single block as a guide.
Thanks for everyone who have tried solve this problem
You could replace the simple block with one that contains the steps, since the smaller steps will be hidden by the bigger ones, when the axis moves down. This should be realistic enough, without adding too much overhead to the collision checking or other aspects of the simulation.
For horizontal covers this might not be as realistic, if you add the fully expanded cover, since the covers can stick together in different ways until they are fully expanded.
So the most realistic stepped covers with the least overhead are fully expanded covers designed. Sure they will extend through the machine bottom or sides, but that is usually no problem, it just looks odd Smiley Wink
Siemens Pioneer
Hi Stefan. Would be a great solution for me, but, the main idea of my question are really about how to move bodies with an interference using assembly, to make the moves automatically. The idea that you proposed is a great idea, and I'll consider to utilize in my machine simulation.
i thank for your collaboration.
Using sequencing each step of the cover would have its own path length, I think.
The smallest one is steady, the second one moves up the height of the smallest one.
The third one moves up the height of the previous two and so on, until the last moves up the entire distance.
May be you could use a deformable part and cheat for the assembly, so your cover is more like a zig-zack pattern.
Simulating way covers?
Of all the **bleep** we need in NX I sure hope this isnt put on developments plate...
Dennis Rathi
Creations Unlimited
Siemens Pioneer
Thank for your information Stefan.
But the idea of deformable part is not a good solution. This could compromise the performance. My biggest question is why NX don't consider the automatic movement of each component of the assembly when they get a collision. But we can consider this topic as solved.
Siemens Pioneer
Hi Dstryr!
You are ok. Really this is not so important.
