Re: Threadmill double start acme threads.... OD and ID
My main concern is why does NX not support threadmill shape and verify correctly?
Dennis Rathi
Creations Unlimited
Well thanks to another member of this forum I was able to figure it out. I guess in a double acme thread your normal "pitch" is not what you actually threadmill. You have to look up the "lead" which ended up being 2x the pitch for a double start.
So the thread is a 2.5 major - .200 pitch which means you cut a .400 pitch twice 180* apart.
The same member also helped me figure out how to 3d verify and confirm I was getting correct results with my acme threadmill operation.
2016-04-25_1529
Dennis Rathi
Creations Unlimited
Looks great! did you use a drive curve or threadmilling?
Threadmilling with "Tool Assembly" for 3d verification.
Dennis Rathi
Creations Unlimited
That is great! Will have to look that up!
