Tolerance variable
Hi guy,
Could you let me know how to find the tolerance varible from NX? Then I can use it for the post.
Thanks!
UG3.0
UG6.0
NX10.0.35
NX11.0.1
UG_NX is my favorite !!!!!!
Re: Tolerance variable
Hi
Try this:
mom_inside_outside_tolerances(0)
mom_inside_outside_tolerances(1)
Marek Pawlus, NCmatic
Development: C#, Tcl/Tk, CSE
you have to turn this on.
Then postprocessing create 3 files where you can find more variables..
example: In your case , open debug file and look for 0.022 and you will find  "variable" == 0.022
