Re: Tool Compensation in Variable contour (Mill-turn)
And - I have REAL 3D-compensation. I can generate toolpath for tool D20R1, but use D20R0, D10R5 D16R1 - any size, with radius or without radius, and - any stock to miling surfaces - +or-....
Of course, I also used full 3D cutcom - although it is not always needed.
These are just two different approaches: one is more complex and other is more easy to use.
Marek Pawlus, NCmatic
Development: C#, Tcl/Tk, CSE
is this same with integrex mazak?
If you are asking about G41.5, it is an option, so you need to check at your machine.
