Re: Tool Library Harvey/Helical/Micro100 tools
Thais @59holloman !
I'll try to do this tomorrow. I'll be working in a tool library and I've been studying a way to change or add different holders in a an tool assembly according I need to do the operation.
Engineer and NC Programmer
NX 12.0.2 mp11
@59holloman  I am going to test this, when using 3D verify does the pattern show up by default as long as it is defined? The docs are very vague on this.
Glenn Balon
Production: NX 12.0.2 MP10 Primarily CAM
https://community.plm.automation.siemens.com/t5/Tech-Tips-Knowledge-Base-NX-Manufacturing/CAM-Faceti...Smiley Surprised
Cheer's
EDS UG V3 -UG V15 UNIX; UGS UG V6 -UG V19 - NX-NX5 UNIX/MS;
Siemens NX6-NX10; NX11; NX12; NX1847~Infinity MS
The sample shows nothing about verification. Does this only work when using machine sim? All I get is an error "Missing kinematics base component"
I was able to add a pattern and point to the file in the display settings. I can see it if I hit replay, but other than that, what is its use?
Glenn Balon
@59holloman I was looking into this and I do not believe NX12 can use these pattern files for simulating in 3D Verify. Is this a new feature for 1847?
Glenn Balon
