Tool Path Visulization - Replay not diaplaying path.
Hello All,
In Tool Path Visulization - Replaying an operation does not diaplay the path.  I have to change the tool trace mode to get it to display which leads me to believe it's bugged.
Is anyone else experiencing the same behavior?
NX 12.0.1
Re: Tool Path Visulization - Replay not diaplaying path.
If the Tool Trace is set to Tool Tip, is the path displayed?
Yes, tool tip is the default.  I have to change it to ball center or none then I go back to tool tip.
NX 12.0.1
Sometimes it works but frequently I have to use the pull down to get it to display properly.  I usually concern myself with bigger issues but when I have the time I investigate my looong list of nagging bugs.
Smiley Wink
NX 12.0.1
I have not seen this. If you can catch it in the act, please log something wiht GTAC.
