Tool Side Milling (Cutting Plastic)
Hello everyone,
would anyone advise me what would be the best operation for trimming the attachment model? This is about milling the red-marked faces of the side of the tool in one operation.
Thank you
Re: Tool Side Milling (Cutting Plastic)
In my attached prt-file I use Multi-Axes Swarf Drive based on isoparametric of the red faces.
Could be this be a solution that you are looking for ?
I need this cut to be around.
Here the solution as an example.
To select all faces as drive-geometry you have to change the settings in selection-preferences...
Thanks a lot. That's exactly it.
Great that it helped, but please take care of any collisions. Actually there is no Workpiece defined (in order to this swarf drive Operation).
Greetings,
Andre
