Tool path ISV - strange axis move at end of block
I have built a couple of machines that have not had an exact match in the sim examples (and some that have which worked ok.) When I run tool path simulation - they have odd moves at the end of each block in the X axis (the one I am working on is a horizontal single spindle mill with a table B and head A.) My question is - with tool path simulation (not code) - is there something (without machine configurator license) that I can do to fix tool path simulation? Tools load up fine. Preview motion on the axes is fine. I am not sure what tool path simulation depends on from CSE or other support files - I would have thought that it only depended on the Machine Tool Builder models.
Windows 7 Pro
