Toolpath motion change from arc to line
Hello all,
I have created a toolpath for the part as below, The edge of part is Arc (R)
          When R=2000 -->Motion output type arc
                    R=4000-->Motion output type line
Where I set in NXCAM  to R=4000 then motion output type = arc
Please see video in attched file for detail.
Re: Toolpath motion change from arc to line
hi all,
I've found a way to set
Just in case you see it later... Note that the post (Circular move event) also has a max (and min) arc radius.
