Toolpath recommendation.
I'd like to machine everything in white finishing the floors and finishing the walls with approximately a .075" step down.  There are three different floor levels and the walls are all vertical.  I've tried FLOOR_WALL, FINISH_WALLS and PLANAR_PROFILE without much luck.  FLOOR_WALL gives me something but there are a lot of wasted moves and the cutter goes up on top the faces I already cut.
Re: Toolpath recommendation.
Hi @Matt_WI,
would you be able to share the part?
Cheers,
Alexander
Lead Product Manager - Mold & Die
Do you want to machine in one operation? I would split in multiple.
When I see faces to be milled I like face milling with boundaries.
Also a real good canidate for cavity milling
{Paul Schneider}, {CNC Programmer}, {DRT-Rochester}
Production: {NX11.0.2,MP5, NX12.0.2, MP4}
Cavity mill or Z-Level would do this in one operation
John Joyce, Manufacturing Engineer,
Senior Aerospace
NX 11.0.2.7 Vericut 8.0.3 - Statements and opinions are mine alone and do not reflect
the opinion of my employer or any other member of the human race
Yes, could you please tell me how and what to all include?  Thanks.
In CAVITY_MILL I have selected only the walls and faces I want to cut and it has a lot of air cutting and is also cutting some (but not all) of the angled faces I have not selected?  I'm using Profile for a Cut Pattern.
I would recomend reviewing some of the tech tips
For example
https://community.plm.automation.siemens.com/t5/Tech-Tips-Knowledge-Base-NX-Manufacturing/Optimize-R...
Senior Aerospace
None of the Cut Pattern options or the Pattern Direction options when the Cut Pattern option is set to Follow Periphery get rid of all the extra moves.  And why are all the extra moves only produced on only part of the fixture?
ZLEVEL_PROFILE seems to give me what I want.
