Re: Toolpath recommendation.
way too many retracts. if you are going to stitch, have you tried changing your cut direction to "mixed" and your connections to "direct on part"?
You can turn on Cut Between Levels in Z Level Profile so the floors can be cut in the same operation. Some programmers prefer a separate operation to finish floors but I frequently use Cut Between Levels.
NX 12.0.2
