[Turning] Cut Resion Down.
Solution Partner Innovator Solution Partner Innovator
Hi
NX version is NX11.0.2.
The problem is where the cut area changes.
I have two MCS.
ROUGH operation has the following cut area.
But FINISH operation has the following cut area.
IPW is changed by the MCS distance difference value.
What should I do to prevent it from changing?
3 REPLIES 3
Re: [Turning] Cut Resion Down.
not sure why you would do this.
A second turning workpiece with blank "From Workspace" will do what you want
Hi.
Two machining origin points are used for one workpiece position.
