Turning-Formtool with concave corners
Hello! How can I define a turning-formtool with concave corners like this:
2017-10-17 09_46_08-NX 10 - Fertigung - [einstech_test_wfl_0 (Geändert) ].png
It's a tool for grooving.
Thank you all.
Werner
Production: NX12.0.2, FBM | TcUA 11.4.0.6
Development: VB.NET, Tcl/Tk
4 REPLIES 4
Re: Turning-Formtool with concave corners
Tool type = turning
Tool subtype = Form Tool
In NX10 it looks like this:
Once the dialog comes up, hit your "F1" key to get context senistive help.
It also might help to (in a "junk" part) create a sketch/drawing with the profile, then you can do "info" (or add dimensions) to get the data the form tool dialog needs.
Hello!
That was clear to me. I know what type of tool this must be. Have you ever defined a concave corner? This is what I do not succeed.
Werner
Werner
Hello Werner,
Please look into my attached example or the picture below. I think this should help.
greetings,
Andre
Hello Werner,
Please look take a look a my attached example or the picure below. I think this should help.
