[Turning]How to create tool path
Hi
I am creating a Turning tool path.
The area is the following V-HOM.
I want to create one vertical line of toolpaths.
Currently, it is made by "TEADCH MODE" method.
But it is uncomfortable.
Is there an easier way? Thank you for your advice.
Re: [Turning]How to create tool path
Siemens Legend Siemens Legend
Siemens Legend
The 35 degree diamond insert will violate the part geometry, and only cut what it can. It probably could rough it out, but not finish it. Unless you use a tool that will not violate the geometry , teach mode is what you will have to use.
