Turning - IPW transfer Issue
In NX12.0.1, turning ipw transfer issue still continues. Also, the problem is same in NX11.0.2.
Is there any enhancement on this problem or coming soon?
Workspace option works properly to transfer the turning IPW from one setup to another, but to use ''IPW - In Process Workpiece'' option is more flexible and no need to struggle with Workspace option.
Thank you in advance!
Ahmet ÜNKÜR
Cad/Cam Engineer
Re: Turning - IPW transfer Issue
Hello @JuergenBecker ,
Thaks for your reply. I have always tried this way at first but it didn't work anyway. I attached the part, please have a look at it. Maybe i'm doing something wrong. Btw i'm using NX12.0.1 .
Have a nice day.
Ahmet ÜNKÜR
Cad/Cam Engineer
in the turning workpiece 1 you should select "Workspace" for the Blank Boundaries. Then it works.
Here is the modified part
Hi @JuergenBecker ,
Workspace option is a good alternative but i'm trying to figure out how i can use '''IPW - In Process Workpiece'' option like mentioned in the Tech-Tips?
It gives error at the below when i click ''Update Local IPW from Source''.
Hope this will be fixed NX12.0.2.
https://community.plm.automation.siemens.com/t5/Tech-Tips-Knowledge-Base-NX-Manufacturing/Turning-Wo...
Anyway, thanks for the reply.
Ahmet ÜNKÜR
Cad/Cam Engineer
the workflow for the IPW transfer works like mentioned in the Tech-Tips. I have made a video from NX12.0.2.
Hi @JuergenBecker ,
Thank you for the video.
Ahmet ÜNKÜR
Cad/Cam Engineer
