Turning - IPW transfer Issue
i tried a second setup for turning in NX 12 following this video (link below) and it worked for me, and then when i tried the exact same steps on another part i kept getting unable to update IPW error as shown in the picture below too.
the only difference between both parts is that in the first one the blank was a cylindre i created in the CAD file while in the part attached below i created a bland from the turning_workpiece option.
any help would be appreciated.
Thanks in advance,
video link: https://www.youtube.com/watch?v=k5nlkh33WcQ&t=8s
Helmi Bouali
CAD/CAM Engineer
Re: Turning - IPW transfer Issue
Hello @Helmi
The problem in you part file is that you is not using the blank as a solid body on your first side.
Please, see the attached video.
I hope this helps.
Thanks.
Jean Marcel
Application Engineer
Ally PLM Solutions | PROLIM PLM
Hello Jean,
that solved the problem, it looks like I have to define a solid blank each time I'm working with an IPW Transfer, thank you for your help!
Helmi Bouali
CAD/CAM Engineer
