Turning Post Processor
Hi, Guys
Do you know how to creat a turning post processor with a live tooing ( which live tooling can be use for milling)
Thanks in advance!
Re: Turning Post Processor
Maybe you need a mill/turn post?
You might be able to do it in one post, but it would probably be way more complicated than needed. Your really better off making a milling post and linking it like the guy above said. You can even have a headless post that can determine automatically if it needs to use the milling post or turning post so that it will behave like one post.
Using NX 8.0.3.4
