UNDERCUT
I NEED TO CUT UNDERCUT OF  THE GREEN SET OF FACES , USING MCS MILL,  HOW?
THE TOOL IS T CUTTER DIA 7.8 M"M CAN BE SEEN IN RED OPERATION
THANK"S
AMNON
Re: UNDERCUT
you can use cavity_mill process profile with undercut machining.
I sent you prt file you can look at it
NX 12.0.2.9 MP5 / Testing NX 1847
CanikSoft NC Post-Processing & G-Code Simulation
www.plast-met.com.tr
www.caniksoft.com
Re: UNDERCUT
I dont know what version you use.I sent it with NX10 version again.
www.caniksoft.com
Re: UNDERCUT
I was able to make a decent path using surface area.
Re: UNDERCUT
Hi
Thank you, i use nx10 and i saw you sent me version for 10. but  i can"t open it yet, nx says newer version.
Re: UNDERCUT
Hi
i opened your file, Thank you.
you have been very helpful
Re: UNDERCUT
Hi
i got the right answer, thank"s
