Re: Undercut roughing with IPW and stepovers?
@Michael_Mannino, you mean it was ok after reversing or it went all nuts? I tried reversing with no luck. Path was violating part and didn’t do the smarter stepovers. Would be really nice to use boss milling for undercuts..
my sample worked fine, i did not save it, but will recreate it and post it...
Ok good news bad news
Good news I think I have it working. I had to give a negative top offset of 1/2 the flute lenght so it would gouge the square.
The bad news I cannot get it to respect the IPW. I added an offset that brought the side stock to the corner of the square, but it did work.ScreenHunter_02 May. 25 14.42.gif
