Undercut roughing with IPW and stepovers?
I need to rough this part from the top side with a Woodruff cutter, and as the picture demonstrates, stock width varies a lot. I've tried all kinds of paths, but can't generate stepovers with IPW awereness. If I just offset the path, there's a lot of cutting air.
I've used heavy feed optimizing as a compromise, but there must (?) be a better way.. I'm using CAM express with 3-ax only.
Thanks/Harri
12 REPLIES 12
Re: Undercut roughing with IPW and stepovers?
try boss milling...
Thanks Michael, I did but couldn’t get it to work. Firstly the top of the cutter plunged happily through the square section and secondly, couldn’t get the IPW awareness on the radial stepovers. Did I miss something?
And isn’t your boss milling approaching from the wrong side?
What NX release are you using?
There might be more options if we know what you really have available despite of 2.5D milling.
I’m on the newest release of NX12. All the 3ax stuff, but no full 5ax.
2D option....
Planar Mill Operation
Set part boundary to your cicle boss
Set Blank boundary to outside of box
Use cut levels > user defined > Distance from top to make sure keyseat doesnt cut flange.
Now you can specify follow part cut pattern and it will attack the corners only instead of multiple circle offset paths that cut air 50% of the time.
2018-05-25_0906
Dennis Rathi
Creations Unlimited
@Dstryr, that looks superb! I’ll give it a try as soon as I’m at the computer.
New cut plane transfer option makes it even better.... with stepover control feed rate can save lots of time.
https://community.plm.automation.siemens.com/t5/Discussion-Forum-NX-Manufacturing/Cut-Plane-Transfer...
2018-05-25_0911
Dennis Rathi
Creations Unlimited
I reversed the boss vector, ok after that...
