Undocumented CSE Kernel Commands
I know there are quite a lot undocumented Kernel Commands in CSE Help. I need to know what else can "checkCredentials" command use other than "SoldToID" variable? For example can we use "MacAddress" or "DiskVolumeSerialNumber"? Thanks a lot...
Re: Undocumented CSE Kernel Commands
Hi Tlbn,
thats correct it´s not documented and the desired commands like MacAdress are currently not implemented. If it´s strongly required, please call GTAC that they open a Task for that.
thanks
ThomasF
