Using spline instead of arcs in NX exported KRL
Is it possible to generate KRL with splines instead of arcs when machining holes?
Re: Using spline instead of arcs in NX exported KRL
Possible.. But - why? You have deviations? May be will be useful output quadrant arcs?
Or - for each circle motion you need to add more points for each arc and output as spline.
