Utilites to Compare and Set Operation Parameters
We have some utilities we are testing to help with managing operation parameters.
I am looking for users who perform these types of tasks:
  • Maintaining template parts: When new templates are released, you compare them to your customized templates, to see what is different. Next you merge your specific defaults with the out-of-the-box operations. For example, you change the 20 parameters in every cavity milling operations, every release. There mus be an easier way to keep track of what you change and merge those changes in.
  • Comparing operations: What parameters are different between 2 operations?
  • Setting parameters: You spend 15 minutes getting all your Non Cutting Moves perfect, and now you need to do it again for another operation. You could write a journal, but there must be an easier way.
If this is you, read on...
We are starting with 2 utilities. The first one compares 2 versions of a part, as you do when a new template part is released. It writes a report as a spreadsheet of all the differences in all the operation parameters, like this:
PART 1
PART 2
OPERATION NAME
OPERATION TYPE
PROPERTY
VALUE IN PART 1
VALUE IN PART 2
folder1\PartA.prt
folder2\PartA.prt
CAVITY_MILL
Cavity Milling
builder.CutLevel.GlobalDepthPerCut.DistanceBuilder.Value
6.0000
8.0000
folder1\PartA.prt
folder2\PartA.prt
CAVITY_MILL
Cavity Milling
builder.BndStepover.PercentToolFlatBuilder.Value
50.0000
75.0000
folder1\PartA.prt
folder2\PartA.prt
CAVITY_MILL
Cavity Milling
builder.BndStepover.PercentToolFlatBuilder.InheritanceStatus
TRUE
FALSE
folder1\PartA.prt
folder2\PartA.prt
CAVITY_MILL
Cavity Milling
builder.NonCuttingBuilder.EngageInitialOpenBuilder.MinimumClearance
ExtendAndTrim
SameAsOpenEngage
folder1\PartA.prt
folder2\PartA.prt
CAVITY_MILL
Cavity Milling
builder.NonCuttingBuilder.EngageInitialOpenBuilder.Trim
TRUE
FALSE
folder1\PartA.prt
folder2\PartA.prt
CAVITY_MILL
Cavity Milling
builder.CutParameters.PatternDirection
Automatic
Inward
folder1\PartA.prt
folder2\PartA.prt
CAVITY_MILL
Cavity Milling
builder.CutParameters.Stepover.PercentToolFlatBuilder.Value
50.0000
75.0000
folder1\PartA.prt
folder2\PartA.prt
CAVITY_MILL
Cavity Milling
builder.CutParameters.Stepover.PercentToolFlatBuilder.InheritanceStatus
TRUE
FALSE
folder1\PartA.prt
folder2\PartA.prt
ZLEVEL_PROFILE
Z Level Milling
ExtendAndTrim
SameAsOpenEngage
folder1\PartA.prt
folder2\PartA.prt
ZLEVEL_PROFILE
Z Level Milling
TRUE
FALSE
folder1\PartA.prt
folder2\PartA.prt
FIXED_CONTOUR
Surface Contour
builder.NonCuttingBuilder.SmoothingBuilder.EngRetToleranceSource
MinimizePoints
Specify
I think this has imediate value for those of you who need to compare template parts.
For those that write journals, I imagine the PROPERTY column already has you thinking Smiley Happy
We have a second utility that reads a spreadsheed like this, and sets the parameters in the operations. For example, if you want a part updated to match PartB, the program will set all of the properties listed to the VALUE IN PART 2 column.
Of course, this is just the beginning. We plan do a lot more, and provide these as sample API programs. However, I would like to get your feedback early on. If you would like to see these utilities and try them for yourself, please let me know. I expect we'll do a webinar and then provide them to the attendees for pre-release testing.
Keep in mind that this has nothing to do with dialog customization -- only the parameters.
Mark Rief
Retired Siemens
53 REPLIES 53
Re: Utilites to Compare and Set Operation Parameters
Sounds great! I'm in !
Dennis Rathi
Creations Unlimited
I'm in as well
Thumbs up
Patrick Delisse
KMWE - Aero Engine
NX 12.0, TC 11.2, CAMPOST V22, Vericut 8.2, TDM 4.8
C#, VB, .NET
Before I get my hopes up....
Will this be available for NX10?  Or only for NX11+?
Hi Mark,
I would be interested in this as well.
Dave
NX10.0.3MP13
NX11.0.1
Production
TC10
Vericut 7.3,7.4.1,8.0.2
Yes! Can't wait to try it.
W10 NX12.0.2.9
testing v1847
I am running in 10.0.3 now. Keep those hopes up.
Mark Rief
Retired Siemens
The most important question........
Will this require a new license to access this new functionality?
Call me cynical.
That property column does indeed have me intrigued!
Mike Diamond, CNC Programmer, Orizon Aerostructures Inc.
Production: NX10.0.3.5, Vericut 8.1.4, ICAM V21
Development: VB.NET, Tcl/Tk
Testing: NX12
