Variable def error Siemens Pama machines
Hi Everybody,
I am trying to make a macro program with some uses of the variables for a 840D siemens Pama horizontal machines. I defined the variable at the beginning of the main program as blow:
DEF INT COUNTER=0
DEF REAL TURN
The machines generated alarms for those lines.
Does anyone out there have any idea what wrong with those?
thank you in advanced.
Chris
Re: Variable def error Siemens Pama machines
maybe TURN variable is some kind of system variable
Try to use "_TURN" instead of "TURN"
Marek Pawlus, NCmatic
Development: C#, Tcl/Tk, CSE
actually I used
DEF INT  NTURNS       ( stand for number of turns)
I tried couple others words for variable, but it didnt work.
