Verification Resolution NX8.5
Hi
We machine features as small as 0.05mm and find the resolution in Verification too large.
I tried changing the Chordal Tolerance (Needle distance etc) but it didn't seem to make any difference.  Are there other settings I can change to suit our size of work?
You are on the right track: Increasing the needle count...
  • Increasing the needle count - or decreasing the needle distance - refines the material removal result in Verify. In case of needle distance, please make sure that the customer defauts are set so that they consider the needle distance.
  • Decrease chordal tolerance - this enhances mainly the display accuracy of the tool, but through this also the quality of the material removal.
NX CAM Product Manager
