Very nice Toolpath
Hello all,
How can create toolpath as below (attached part)
Re: Very nice Toolpath
Cutting tool doameter used ?
They use D3-R0.5 tool
I would use Follow Part or Follow Periphery cut pattern with Smooth Non Cutting Moves.
Mark Rief
Retired Siemens
Hi Mark,
The 'follow periphery' result does not look good in NX 7.5....at least not as good as shown in original image. Need to do some additional settings... I have not checked 'follow part' in NX 7.5 or in NX 9 or NX 10.
After machining it may give good finish !
BR,
Mak
I got a decent path in 10.0.2 with a ball cutter:
Mark Rief
Retired Siemens
Dear  Mark,
Could you please guide set parameter and send me this file?
Dear Mark,
I have created Fix Contour operation, result nice toolpath,
Is that the way you do?
@Khang wrote:
Dear Mark,
Yes - use the area mill drive method and pick the top faces as cut area, no steep/nonsteep separation, follow periphery cut pattern inward.
Also, try applying the stepover on part or on plane - the results will be a little different.
Mark Rief
Retired Siemens
