Do you mean
Reply
WIP
How to save the WIP model after simulation for further operations & how use the same WIP in other setup.
Plz reply.
Re: WIP
In NX we call this the IPW, or In Process Workpiece. I think if you search the help for "IPW" you will find what you need.
The IPW can be saved if needed from verify, but that is not necesary if you want to use it as a blank in generating other tool paths. If you use IPW flow, the system will use the IPW from another operation or setup as the starting blank for the new setup.
Mark Rief
Retired Siemens
