WIZD_INFORMATION.OUT
when I use customization it generates this file WIZD_INFORMATION.OUT.
With messages inside:
+++MOM WARNING+++
Info: MISSING EVENT HANDLER: event name: WIZD_mill_planar__mill_planar
NX seems to work normal.
Can you please tell  what does it mean and how to fix it?
Thanks for any help
4 REPLIES 4
Re: WIZD_INFORMATION.OUT
What CAM configuration do you use, cam_general.dat or other?
This file is only created if CAM wizard output is enabled in the CAM configuration, see entry starting with WIZARD.
If you don't use CAM wizards, you can just comment out the line.
yes I am using cam_general.opt  but inside are only template parts, no wiz...
Or where do you exactly mean I should find/comment out it?
I dont know what the cam wizard is Smiley Happy and why it generates warnings.
thank you
I didn't mean the template_set, but the configuration, since I said cam_general.dat
There should be the line:
WIZARD,${UGII_CAM_WIZARD_DIR}wizard_cam_library.tcl
You could also disable the setting "Customer Defaults => Manufacturing => User Interface => Dialog Boxes => Run Process Assistant". In addition there is "Customer Defaults => Manufacturing => User Interface => Palettes => Show Manufacturing Wizard Palettes".
Generally the creation of Wizards is deprecated, if I remember correctly, so if you don't have some, remove their availability.
thank you for explanation
