Watch case (3-ax)
Cool project I have the pleasure to be part of. This is a prototype case made of brass, the final material will be Stavax (AISI 420 mod) After machining, the case will be polished and coated.
CAM and machining wasn't easy, but NX really delivered!
For those interested, the product can be found at haikara.co
Harri
Re: Watch case (3-ax)
Have you recorder the machinig? Also I am interested to see fixtures you used for 2nd and further setups.
Hi Mak,
no recordings. The fixtures are nothing fancy, just a negative of the inner works and a plate to hold the part in place. The same fixture was used for drilling the lugs and finishing the second side.
