What is the funtion of Distance/ Angle Divisions?
When I use the transform toolpath in NX 10, I see the Distance/ Angle Division item. I don't understand the purpose of this function? Can you explain this for me and give me an example? Thanks!
[IMG]http://i.imgur.com/HJO4vpG.jpg[/IMG]
<img src="http://i.imgur.com/HJO4vpG.jpg" />
4 REPLIES 4
Re: What is the funtion of Distance/ Angle Divisions?
This is documented in the online help.
Siemens Documentation
Distance/Angle Divisions
Specifies how many equal parts you want the transformation angle or distance divided into.
If you select Move , the transformation is to the first subdivision of the total distance (or angle).
If you select Copy , or Instance , each copy or instance is spaced according to the subdivided distance or angle.
For example, if you rotate 180 with 3 divisions, the angle is 60 between copies.
I find it easiest to use Show result to see the effect.
Mark Rief
Retired Siemens
Thanks for your reply, but I don't see the difference when I change the value in Distance/ Angle Divisions box?
[IMG]http://i.imgur.com/s8DXHwh.jpg[/IMG]
[IMG]http://i.imgur.com/41ys3JF.jpg[/IMG]
This does not apply to the angle or a rectangular array. Try it with rotate about a point.
Mark Rief
Retired Siemens
I just tried this function with the Circular Array command but I don't see the difference if I change the value in Distance/ Angle Divisions box (I tried with some value as 0, 30, 60, 90 but the result is the same)! Can you make an example for me?
