What's type operation in NX ?
Dear all,
what type of operation  in NX cam can do this toolpath?
(view in My Videos)
attached file is part and nc programe
Re: What's type operation in NX ?
*Fixed contour,
*drive method streamline,
   -2 flows, top and bottom curves, you can add cross vertical curves
   -helical pattern
*projection vector
     -away from line, line in the center of this area
I would also look at tube milling.
thanks for your help!
I think this toolpath like zlevel profile,,, I try out all operation in nx, but toolpath very bad
If you can't get a path you like with Zlevel Profile, please contact GTAC, MBG, or your partner representative.
Zlevel does levels, constant levels,like cavity profile
Notice that in the video the bottom paths are offseted from something and even copy it.
