Wire EDM Start, In and End-of-Path Markers.
I'm curious, how many 2-Axis Wire EDM programmers, who actually use NX to program their Wire EDM's with, use the Start-of-Path, In-Path & End-of-Path Markers provided for this particular module? Did you ever try to use them?
I know that most uses a stand alone Software, usually provided by the EDM builder that's tailored specifically for their machine and it takes care of all those cutting condition settings, feed rates, etc. But if you're using a Progressive Die Wizard, do you use NX or something else to program your Wire EDM with?
