Wise assembly loose all constraint when transfer in manufacturing... why ?
I am using a wise assembly which I want to use in manufaturing. and only open and close the jaw with differente setup.. when in manufacturing I am loosing all my constraint... can not find the problem any clues ? thanks
Re: Wise assembly loose all constraint when transfer in manufacturing... why ?
could you please be more specific, I really can`t figure out the problem ?!
Is it possible that you attache the zipped Partfiles?
Are you working with Master Model assembly?
Picures could also help understanding the Problems
Andre
