Z level profile
Builder
Builder
How to create operation in z level profile zigzag with stepover on part in steep and non steep area(like area miiling method) BUT NOT AS DEPTH OF CUT
7 REPLIES 7
Re: Z level profile
Hi Vora,
Would be interesting to know what speaks against using Area Milling?
You can use Cut Between Levels in Z-Level-Profile for Non Steep Areas, but that won't give you a Zig Zag toolpath.
I would prefer using Area Milling anyways over Z-Level-Profile.
Cheers,
Alexander
Lead Product Manager - Mold & Die
Re: Z level profile
Builder
Builder
What I'm saying comes in Powermill(optimise constant z finishing..It does not take depth per cut but also stepover on part)
Re: Z level profile
Cut levels -optimized
Optimized
Available for Zlevel operations.
Adjusts the depth of cut for more consistent on-part spacing and scallop height.
Optimized creates additional cuts as the slope changes from steep to shallow.
The maximum cut depth does not exceed the Global Depth per Cut value.
Re: Z level profile
Builder
Builder
Is this possible from scallop
And how to calculate if my stepover is 0.1mm
Re: Z level profile
I see no limitation how you set it - by level or scalop
set constant 1 mm  + optimized =
doc
Re: Z level profile
Builder
Builder
Where is optimised option in z level profile
Re: Z level profile
cut levels - cut levels - optimized
