Zero RPM Notification
Just as the title implies, I was wondering if there was a way to be notified when I post process a program, to be told that I forgot to give an operation a speed and feed rate. This would save countless hours having had to walk from my office to my machine and back countless times because in one operation I forgot to set a spindle speed...
8 REPLIES 8
Re: Zero RPM Notification
Siemens Legend Siemens Legend
Siemens Legend
just create a custom command in the Start of Path event where you ask the spindle speed from operation, e.g.:
proc PB_CMD_spindle_check {} {
global mom_spindle_rpm
if {$mom_spindle_rpm==0} {
MOM_display_message "no spindle speed" "warning" "W"
With MOM_display_message you get a warning during postrun.
Best regards
Thomas
I am going to assume this is it post builder? I've never created a custom command before.
or MOM_abort "no rpm, $operation name"
and it shut down postprocesing with the rror message
Could you provide me with instructions on how to do this?
Here's what I ultimately came up with. Thanks for your help fellas!
For anyone wanting to do this that doesnt no how, just copy the image and place the Custom Command under the Operation Start Sequence  ->Initial Move (first line) and again under the First Move line.
Here's the script you can copy and paste to do this quickly:
global mom_spindle_speed mom_operation_name
if {$mom_spindle_speed==0} {
MOM_display_message " Zero RPM in Operation: $mom_operation_name " "Warning" "W"
Once again thanks!
One of the things I do to help prevent this prior to post processing is adding the speed column to the operation navigator. Prior to posting I just scroll over and make sure my speeds and feeds are set.
I know this doesn't answer your question, just something that helps me...
You know what funny. After posting this and everything, I had some free time from programming parts to look more in depth at things I usually just glance over. I found that column know longer than 45 minutes after I posted this. Thanks for the response though!
