add Part
Hey guys,
I got a new computer and we put the old Nx of the last computer on it.
Now I can´t find the button where I add parts into my template. I haven´t worked with Nx for a longer time so I´m not sure if it´s a Nx issue or if I forgot everything I ever learned.
Thank you a lot
4 REPLIES 4
Re: add Part
I'm not sure what button you are refering to. Do you remember the name of the command? Or the icon?
For sure try changing your role to CAM Advanced so that all the commands are available.
Mark Rief
Retired Siemens
Re: add Part
Hallo Mark,
it is the button " add components" and "constraints" I´m searching for.
I need it to put a new part in my template and to fix it in the right direction.
Re: add Part
Check if you have "Assemblies" module turned on:
in File --> Start section --> check "Assemblies"
or in Application ribbon bar --> Design section --> check "Assemblies"
then you should find it in:
Menu --> Assemblies --> Components --> Add Component
Marek Pawlus, NCmatic
Development: C#, Tcl/Tk, CSE
Re: add Part
Thank you Mark,
it was in the design section.
You helped me so much. Thanks
