basic "face milling" question
I am new to NX-CAM, I created a milling operation (Face milling manual) and got that toolpath:
(start of the operation)
The kind of toolpath is OK, but I would like to start at the center of the hole and not outside my surface and cannot manage to do so.
How should I set the parameters of my operation to achieve that ?
Thank you in advance.
          Luis
Re: basic "face milling" question
Use Floor Wall.
Follow Periphery
Go to non cutting moves >> Start / Drill pt tab >> Set a drill point in the center.
Dennis Rathi
Creations Unlimited
Thank you !
Also, in Cutting Parameters, you can set the Pattern Direction to Outward.
Mark Rief
Retired Siemens
