'cannot parse CSE controller configuration' message appear..!
i`m working 4Axis rotary head type machine.
axis type is based on 'XYZ', and added 'B' axis spindle head.
when i choose machine code simulate, this message appear!1.jpgwhen i choose machine code simulate
i don`t have 3+1 head type sample, so i used sample 'sim07_mill_5ax'.
Am i right??
i don`t know how can make new MCF file.
let me know how can i solve this problem.
i will upload MTB infomation, check my data please.
and if you need machine assy file, leave message please...Man Sad
error.jpgMTB infomation
Re: 'cannot parse CSE controller configuration' message appear..!
NX version is 10.0.3
please as a first step check if all the connection between machine tool model *.dat file and MCF are set up correctly. It could be that this is a simple mistake in the configuration. Here some overview slides about htat:
Hope it helps
Thomas
Thomas Schulz
Siemens PLM
