cav-5 axis
you guys could help me and make the best of roughing and finishing strategy in this cavity 5 axis
Re: cav-5 axis
Hi Claudio,
This actually can be done using 2 cavity mill operations in 3X positioned corectly. when you set the cvity mill operations make sure that both operations have the 'Cut below Overhanging blank' unchecked (cutting parameters, strategy tab). for the second operation set the 'In Process workpiece' to use 3D and set a minimum material remove >0 and < depth per cut (i.e. 0.5).
I created operations and generated it on 11 and can upload the results. which NX version do you have?
Eddy Finaro
NX CAM Product Manager
Siemens PLM
Re: cav-5 axis
The part history tells us that the OP is on NX 8.5.3 Smiley Wink
