combine output files from sync manager PB_CMD_combine_nctapes?
I was hearing that Siemens created something to do this by adding the proc PB_CMD_combine_nctapes but I don't know how to use it. I just copied and pasted in a custom command, but get an error that it doesn't exist. Do I need a whole copy of the proc?
Using NX 8.0.3.4
Re: combine output files from sync manager PB_CMD_combine_nctapes?
Esteemed Contributor
I would contact GTAC to see if they can get you the proper code.
Apparently I've turned into a gearhead
Ok, I just did that. I was hoping to get a quicker response from the forum. I can't be the only person using a twin turret okuma with NX.
Using NX 8.0.3.4
From what I know, you need to add the custom command to end of program in the main post.
Is that what you tried?
Mark Rief
Retired Siemens
I am assuming he has the name of the custom command needed, but not the code that goes in it.
I'm not sure I can post what Siemens provided to me in the machine kit we bought, (plus that's many years old) so he needs whatever the current version of the proc is.
Note (to my knowledge) this is needed on at least Okumas and Mazak Integrexes.
Not sure about other control types.
yes, Ken is correct on that. I need the code. Just mainly interested in seeing how the files are connected. Do they make a separate combined file while keeping the upper and lower turret files?
Using NX 8.0.3.4
