cut area setting for turning operation.
Solution Partner Innovator Solution Partner Innovator
Hi.
I am creating a turning operation.
The remaining amount after machining is shown below.
In process workpice are away.
I want to create a tool path with one operation.
Is there a way?
Re: cut area setting for turning operation.
Yes, of course.
To be able to machine multiple regions in one turning operation, you should set this option:
Cut Regions --> Region Selection tab --> Region Machining
set it to Multiple
Marek Pawlus, NCmatic
Development: C#, Tcl/Tk, CSE
Thank you
