does not work, change the default setting
Today I change the default setting as attached image 1. Then I restart the NX, But it does not change in the attached image 2. I tested this in the NX10-11. That is same thing. So could someone meet same issue?
Thanks!
UG3.0
UG6.0
NX10.0.35
NX11.0.1
UG_NX is my favorite !!!!!!
Re: does not work, change the default setting
After you change Customer Defaults, create new part (use Blank template, not Model)
Then you should see your defaults applied.
Those settings are stored together with each PRT file.
Marek Pawlus, NCmatic
Development: C#, Tcl/Tk, CSE
Thank you so much! Marek!
I already try. It works!
UG3.0
UG6.0
NX10.0.35
NX11.0.1
Last week I was describing this options here:
https://ncmatic.com/technical-tuesday/visualization-quality/
I already friend with you in PLM forum, Youtube and Facebook! ^_^
Thanks!
UG3.0
UG6.0
NX10.0.35
NX11.0.1
