drilling NX11
I just begin to use the new operations of drilling in NX11 and my knowledge in the new operations of drillings are nothing...!
Holes are not modelled, I just have points and 2 surfaces (begin and depth of holes) and all my points have to be according to a vertical band
How to do it ?
I tried to do :
Select point to point > I gave up...Man Indifferent
Select all the points (crtl+A) > impossible to find normal
depth according to my end surface > I don't know..
Vertical band according to vecteur Y > I gave up... to
any help will be appreciated
attached example (Nx7.5)
Production: NX11.0.2.7,VERICUT 8.1.2
Development: Tcl/Tk, Gnuplot
www.adgroupe.com
18 REPLIES 18
Re: drilling NX11
https://community.plm.automation.siemens.com/t5/Tech-Tips-Knowledge-Base-NX-Manufacturing/Drilling-H...
Maybe this video can help you.
NX 12.0.2.9 MP5 / Testing NX 1847
CanikSoft NC Post-Processing & G-Code Simulation
www.plast-met.com.tr
www.caniksoft.com
Re: drilling NX11
yes i know , it's a good example for a basic part... , i don't use a solid ,just 2 surfaces and points
thanks anyway
www.adgroupe.com
Re: drilling NX11
How have the points been created?
Have you tried to tag the points to get machining features?
You know that the new drilling is working totally different than the ancient P2P and that there might never be support for drilling with only points, top and bottom faces.
Re: drilling NX11
points file
i don't know , can you tell me a little bit about that ? or give me a link ?
I understand but I hope for a solution to my problem , everything is projection in Nx Smiley Wink
www.adgroupe.com
Re: drilling NX11
See the NX documentation about tagging features. Also display the navigation panel to the left to have easy access to related topics.
Re: drilling NX11
thanks for the link
www.adgroupe.com
Re: drilling NX11
tag is not a solution for me ,select every points, define a vector for every points, for about ten points it is ok but more than hundred it is too long...
P2P I miss you...Smiley Sad
www.adgroupe.com
Re: drilling NX11
This may not be the answer your looking for but you can still use the "Old" p2p operations.
open up the .opt file
For example
C:\Program Files\Siemens\NX 11.0\MACH\resource\template_set\cam_general.opt
and uncomment the drill.prt
Remove the hashtags
## ${UGII_CAM_TEMPLATE_PART_ENGLISH_DIR}drill.prt
I am still using PTP.   I need the Engage and Retract motion on many operations and that is not availble in Hole Making.
John Joyce, Manufacturing Engineer,
Senior Aerospace
NX 11.0.2.7 Vericut 8.0.3 - Statements and opinions are mine alone and do not reflect
the opinion of my employer or any other member of the human race
Re: drilling NX11
thanks John , I think that if Siemens still leaves "Old" P2P , it is other users are not satisfied yet but for how long ?
www.adgroupe.com
