engraving
Re: engraving
Have you already tried fixed contour with drive curve?
Re: engraving
If you use Surface Contouring with Curve/Point drive method, and NO part geoemtry, the tool should follow the curves as you show.
Mark Rief
Retired Siemens
Re: engraving
Hm.... My chance to understand topic starter, I will use telepathy.
If you see a picture - topicstarter want ZIG-ZAG. In this case - Variable Contour, Surface Area as drive method. Surface? Extrude 3D spline or Swept, Or By curves, etc - depends what topic sterter want.
Re: engraving
i wan to make -z steps in zig zag , and only have a curve, thx
Re: engraving
I can get Zig by turning on multiple depths. The trick is that this requires part geometry, so you need to also select the spline as part.
Mark Rief
Retired Siemens
Re: engraving
Or extrude this spline in Z direction and use this Surface as Surface Area drive geometry with option Tool On, no part, zigzag..
Re: engraving-
CAN YOU MAKE A VIDEO DEMONSTRATING HOW TO MAKE THIS TYPE OF MACHINING?
CLAUDIO
