error - cannot build grid (drive geometry will be erased)
Hello All
I'm new to using NX9 and I'm playing around trying to create a toolpath using the variable contour surface area method.
When selecting adjacent drive surfaces I get the error "cannot build grid (drive geometry will be erased)"
I'm trying to create a roughing toolpath for a model F1 crankshaft  between centres on a 4 axis mill
Can anyone shed any light on the problem?
Re: error - cannot build grid (drive geometry will be erased)
It is impossible to use an entire body as the drive geometry.
In your case you should create a bounding cylinder and use the cylindrical face as the drive geometry.
Thank you
I then seem to end up with this.......
Do not use the solid body as the drive surface, just the cylindrical face.
Never use a body as the drive geometry.
Many thanks Stefan
ok ... so now I have a cylinder and the face of the cylinder is selected as drive geometry.
With the entire crank specified as the part, and no cut areas defined, this is the toolpath that gets generated with the tool aligned along the x axis. I can change the tool vector etc but don't seem to be able to generate a tool path where the crank rotates about the C axis and cutting motion is in Z / Y
Same if I select cut area as below ....
Any thoughts on the best approach?
I managed to achieve this when trying out a cam lobe, but in that situation, I selected the upper and lower faces of the lobe as drive geometry.Capture7.PNG
Attached find a sample part file.
Make sure to select the correct cut direction.
Thank you Stefan, unfortunately the zip file only seems to contain empty folders ....
It contains a part file, make sure to use 7-zip v16.02, any older release will not be able to open it correctly.
ok sorted. I now have the part open.
That looks perfect ... exactly what I want to do.
Please give me some time to look at how you set it up.
Stefan ... I can't thank you enough.
Roger
